HP Chromebook 14-q029wm Motherboard Replacement
  1. HP Chromebook 14-q029wm Motherboard Replacement, Keyboard: step 1, image 1 of 1
    • Remove nine 5mm Phillips #0 screws from the back case.
    • Remove the rubber caps using a spudger.
    • Remove the four remaining 5mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Motherboard Replacement: step 2, image 1 of 1
    • Use an opening tool to unclip the bottom plastic covering of the laptop.
    • Go around the sides of the laptop until the bottom unclips completely and comes off of the laptop.
    • Be careful not to break the plastic clips.
  3. HP Chromebook 14-q029wm Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
    • There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
    • Remove the larger wire first.
    • Then remove the smaller wire.
    • It is better to use a pair of tweezers for accuracy
    • From there the keyboard should completely come off.
  4. HP Chromebook 14-q029wm Motherboard Replacement, Battery: step 4, image 1 of 1
    • Use your fingers to pull the white tab out of the black slot above the battery.
  5. HP Chromebook 14-q029wm Motherboard Replacement: step 5, image 1 of 1
    • Remove the 3mm Phillips #0 screws.
  6. HP Chromebook 14-q029wm Motherboard Replacement: step 6, image 1 of 1
    • Pick up and gently remove the battery.
  7. HP Chromebook 14-q029wm Motherboard Replacement, Fan: step 7, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement, Fan: step 7, image 2 of 2
    • Remove the three 3mm Phillips #0 screws.
    • The bottom right screw may be covered by the fan's wires.
  8. HP Chromebook 14-q029wm Motherboard Replacement: step 8, image 1 of 1
    • Using your fingers or an opening tool, remove the cable connecting the fan to the motherboard.
    • Gently remove the fan.
  9. HP Chromebook 14-q029wm Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Remove the five 2mm Phillips #0 screws from the motherboard.
  10. HP Chromebook 14-q029wm Motherboard Replacement: step 10, image 1 of 1
    • Unclip the black lever holding the connector in place to the motherboard and remove the connector.
  11. HP Chromebook 14-q029wm Motherboard Replacement: step 11, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement: step 11, image 2 of 2
    • Unplug the wire connecting the speaker to the motherboard.
  12. HP Chromebook 14-q029wm Motherboard Replacement: step 12, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement: step 12, image 2 of 2
    • Remove this connector found under the right side of the motherboard.
  13. HP Chromebook 14-q029wm Motherboard Replacement: step 13, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement: step 13, image 2 of 2
    • Lift the right side of the motherboard slightly and slide the USB and other ports out from the left side.
    • The motherboard should be able to turn on its side after that.
  14. HP Chromebook 14-q029wm Motherboard Replacement: step 14, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement: step 14, image 2 of 2
    • Remove the four 2mm Phillips #0 screws from the heat sink.
    • Remove the heat sink from the motherboard.
  15. HP Chromebook 14-q029wm Motherboard Replacement: step 15, image 1 of 2 HP Chromebook 14-q029wm Motherboard Replacement: step 15, image 2 of 2
    • Looking at the right side of the motherboard, remove the Wi-Fi card that is connected to the motherboard.
  16. HP Chromebook 14-q029wm Motherboard Replacement: step 16, image 1 of 1
    • Remove the black wire from the screen.
    • Remove the motherboard from the laptop.
Andrew Pratt
669 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 446
