HP Chromebook 14-q010nr Touchpad Replacement
  1. HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: step 1, image 1 of 3 HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: step 1, image 2 of 3 HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: step 1, image 3 of 3
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Use an opening pick to separate the keyboard from the chassis.
    • Lift the keyboard away, with care not to damage the connected ribbon cables.
  2. HP Chromebook 14-q010nr Touchpad Replacement: step 2, image 1 of 2 HP Chromebook 14-q010nr Touchpad Replacement: step 2, image 2 of 2
    • Flip up the black lock bars on the ZIF connectors, then remove the ribbon cables.
  3. HP Chromebook 14-q010nr Touchpad Replacement: step 3, image 1 of 1
    • Gently raise the keyboard from the device and separate the two components.
  4. HP Chromebook 14-q010nr Touchpad Replacement, Touchpad: step 4, image 1 of 2 HP Chromebook 14-q010nr Touchpad Replacement, Touchpad: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Unscrew the two screws securing the touchpad to the keyboard with a Phillips #00 screwdriver.
    • The touchpad may fall out of its position after removing the screws, so carefully remove it with tweezers.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 149
