Introduction
This guide requires removal of 2x5mm screws attaching the speakers to the frame of the laptop.
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Remove the two screws indicated by the red circles.
Using fingers or the spudger, slide out the black connector indicated by the orange rectangle on the left.
Undo the black tape indicated by the middle orange rectangle from the frame of the laptop
