Introduction
The Speaker Replacement Guide provides the steps required to remove the HP Chromebook’s speakers. The speakers may need to be replaced if the audio becomes distorted or no sound can be heard from the device. Before removing the speakers due to audio problems, ensure all troubleshooting steps have been completed in accordance with the audio section of the Troubleshooting Guide. To access the speakers, the keyboard and battery must be removed first.
Removing the keyboard will expose the internal components of the computer. These components are electrostatic discharge (ESD) sensitive components. It is important to ensure that an anti-static wrist strap and anti-static mat are used to prevent ESD from damaging other components inside of the device. For proper use of the anti-static wrist strap, refer to iFixit’s “How to set up your Anti-static mat and wristband” Guide.
Disconnect the power adapter from the charging port and remove all external media devices from the Chromebook.
Turn the Chromebook over so the bottom of the computer is facing upwards with the hinge facing away.
Place the Chromebook upright and open the screen all the way.
Starting towards the hinge, insert the spudger between the silver keyboard decking and the charcoal colored casing.
Pry upwards to release the tabs that are securing the keyboard to the casing.
Repeat this process around the perimeter of the keyboard to ensure all tabs are released.
Once all the tabs are released, gently lift the keyboard to gain access to the (2) Zero Insertion Force (ZIF) ribbon cables.
Using the hook on the halberd spudger, lift the external media board ZIF connector attached to the motherboard.
Using either side of the spudger, disconnect the speaker cable from the bundle connector located on the bottom of the motherboard.
