Introduction
Through over-heating or damaging the laptop by dropping it, the motherboard will not be able to function. This guide will help replace it.
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
Lift up the small black rubber cap until it is completely off.
Repeat this step one more time to remove the other small black rubber cap on the other side.
Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
Lift the spudger a little in the front of the keyboard until the key board lifts up.
With your hands, slowly and carefully lift the key board up.
Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
Slowly unplug this wire that connects to the key board.
Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
Find the wire that connects the screen to the motherboard.
Lift black tab that holds the wire in place.
Remove the wire.
Find the display cable that connects the screen to the motherboard.
Lift black tab that holds the display cable in place.
Remove display cable.
Use a Phillips #0 screwdriver to remove the four 1.3mm screws that hold the screen in place.
Use a Phillips #0 screwdriver to remove the one 1.3mm screw that connects the speakers and the motherboard together.
Slowly and cautiously unplug the wire that connects the speakers to the motherboard with your hands.
Locate the wire at the top of the motherboard.
Lift up the black tab that holds the wire in place.
Remove the wire.
Locate the wire that connects the USB port and the motherboard.
Lift up the black tap that holds the wire in place.
Remove the wire.
Use a Phillips #0 screwdriver to remove five 1.3mm screws that hold the motherboard in place.
