Introduction
Use this guide to remove the display assembly of the HP Chromebook 11 G3.
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Flip the laptop so it is in the upright position.
Open the lid.
Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
Gently pull the ribbon cable out of its socket.
Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
