HP 7 1800 Front Facing Camera Replacement
  1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: step 1, image 1 of 2 HP 7 1800 Front Facing Camera Replacement, Remove the back panel: step 1, image 2 of 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: step 2, image 1 of 3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: step 2, image 2 of 3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: step 3, image 1 of 2 HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: step 3, image 2 of 2
    Buy
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: step 4, image 1 of 2 HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: step 4, image 2 of 2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 silver screws from the logic board: step 5, image 1 of 1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Front Facing Camera Replacement, Unplug the front facing camera from the logic board: step 6, image 1 of 1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Front Facing Camera Replacement, Remove the logic board: step 7, image 1 of 1
    • Carefully lift the motherboard directly up.
  8. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: step 8, image 1 of 2 HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: step 8, image 2 of 2
    • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
  9. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 black screws on the metal plate: step 9, image 1 of 1
    • Unscrew the following black screws:
    • Seven 2.82mm Phillips #00 around the metal casing.
  10. HP 7 1800 Front Facing Camera Replacement, Remove the metal plate: step 10, image 1 of 1
    • Gently lift the metal plate directly up.
  11. HP 7 1800 Front Facing Camera Replacement, Remove the camera: step 11, image 1 of 1
    • Gently remove the camera from the device with tweezers by lifting it up and out of its square hole.
Trevor Shumate
225 Reputation
2 Guides authored
USF Tampa, Team 4-1, Brown Winter 2015 Member of USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 243
