Shop the Holiday Gift Guide
HP 20-c010 RAM Replacement/Upgrade
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
72
All Time:
174
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The HP c010 series features socketed RAM, leaving the end-user the ability to upgrade to a max of 8GBs using DDR3 SODIMM sticks. This can provide a significant performance boost, especially if the PC is struggling with browsing the web or tasks that require significant memory usage.
This guide is meant to guide end-users when upgrading the RAM of the system
Before starting, please ensure the computer is powered off and unplugged from its power source
    1. HP 20-c010 RAM Replacement/Upgrade, Remove the foot assembly from the unit: step 1, image 1 of 3 HP 20-c010 RAM Replacement/Upgrade, Remove the foot assembly from the unit: step 1, image 2 of 3 HP 20-c010 RAM Replacement/Upgrade, Remove the foot assembly from the unit: step 1, image 3 of 3
      • Carefully rotate unit so that its "foot" assembly is facing up, as shown in the photo
      • Unscrew the two #2 philips screws with a screwdriver
      • Remove the foot from the unit
      Ask FixBot
    2. HP 20-c010 RAM Replacement/Upgrade: step 2, image 1 of 2 HP 20-c010 RAM Replacement/Upgrade: step 2, image 2 of 2
      • Remove the Philips screw where the foot assembly was
      • This screw secures the display bezel assembly
      Ask FixBot
    3. HP 20-c010 RAM Replacement/Upgrade, Remove the display bezel: step 3, image 1 of 3 HP 20-c010 RAM Replacement/Upgrade, Remove the display bezel: step 3, image 2 of 3 HP 20-c010 RAM Replacement/Upgrade, Remove the display bezel: step 3, image 3 of 3
      • Carefully use a guitar pick or similar opening device to separate the two halves of the display assembly at the seam
      • These clips can be a bit tricky to locate and may require additional force to release
      Ask FixBot
    4. HP 20-c010 RAM Replacement/Upgrade, Carefully separate the display: step 4, image 1 of 1
      • Remove the display from the other half of the computer, set to the side
      • Avoid damaging the ribbon cables that connect to the display and webcam
      Ask FixBot
    5. HP 20-c010 RAM Replacement/Upgrade, Locate the RAM slots: step 5, image 1 of 3 HP 20-c010 RAM Replacement/Upgrade, Locate the RAM slots: step 5, image 2 of 3 HP 20-c010 RAM Replacement/Upgrade, Locate the RAM slots: step 5, image 3 of 3
      • Locate the RAM slots near the CPU cooling assembly on the motherboard
      • Press in the retaining tabs to release the memory for removal
      • Slot in a new stick at a 45° angle, and press down until a click is heard
      Ask FixBot
Author
with
Cloudy Flynn
282 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 72
All Time: 174
