HP 17-bs049dx Back Panel Replacement
  1. HP 17-bs049dx Back Panel Replacement, Battery: step 1, image 1 of 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Back Panel Replacement, Back Panel: step 2, image 1 of 1
    • Remove panel screws (13.7mm) with "Phillips 0 screw driver" connecting back panel to frame.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Back Panel Replacement: step 3, image 1 of 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Back Panel Replacement: step 4, image 1 of 2 HP 17-bs049dx Back Panel Replacement: step 4, image 2 of 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Back Panel Replacement: step 5, image 1 of 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,504
