HP 15-db0004dx Fan Replacement
  1. HP 15-db0004dx Fan Replacement, Bottom Case: step 1, image 1 of 2 HP 15-db0004dx Fan Replacement, Bottom Case: step 1, image 2 of 2
    • Turn the laptop off and unplug it before starting.
    • Flip your laptop over, face down.
  2. HP 15-db0004dx Fan Replacement: step 2, image 1 of 1
    • Peel off the two long rubber grips running lengthwise on the laptop.
  3. HP 15-db0004dx Fan Replacement: step 3, image 1 of 2 HP 15-db0004dx Fan Replacement: step 3, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
  4. HP 15-db0004dx Fan Replacement: step 4, image 1 of 1
    • Carefully slide the optical drive out of the laptop.
  5. HP 15-db0004dx Fan Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to separate the back panel from the laptop.
    • For an easier removal, start at the corner and run the tool along the edge of the cover.
    • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
    • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
  6. HP 15-db0004dx Fan Replacement, Fan: step 6, image 1 of 3 HP 15-db0004dx Fan Replacement, Fan: step 6, image 2 of 3 HP 15-db0004dx Fan Replacement, Fan: step 6, image 3 of 3
    • Using a Phillips #000 screwdriver remove the 5mm screw holding the fan in place.
  7. HP 15-db0004dx Fan Replacement: step 7, image 1 of 3 HP 15-db0004dx Fan Replacement: step 7, image 2 of 3 HP 15-db0004dx Fan Replacement: step 7, image 3 of 3
    • After the screw is removed, carefully unplug the set of wires with one of each colored, red, black, yellow, and blue, from the white connector it is secured at.
    • To unplug it gently pull the white connector from the adapter, possibly in a back and forth motion to free it.
    • DO NOT pull on the wires, doing so could cause damage to the wires, or for them to become disconnected to the white adapter they are attached to.
  8. HP 15-db0004dx Fan Replacement: step 8, image 1 of 3 HP 15-db0004dx Fan Replacement: step 8, image 2 of 3 HP 15-db0004dx Fan Replacement: step 8, image 3 of 3
    • Carefully remove the fan from the laptop.
    • Be careful with removal as to not bend or break anything. There is a metal peg shown in the image, that the fan is secured on that could potentially bend
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 274
