HP 15-af013cl Motherboard Replacement
  1. HP 15-af013cl Motherboard Replacement, Battery: step 1, image 1 of 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: step 2, image 1 of 3 HP 15-af013cl Motherboard Replacement: step 2, image 2 of 3 HP 15-af013cl Motherboard Replacement: step 2, image 3 of 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: step 4, image 1 of 2 HP 15-af013cl Motherboard Replacement: step 4, image 2 of 2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: step 5, image 1 of 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: step 6, image 1 of 2 HP 15-af013cl Motherboard Replacement: step 6, image 2 of 2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: step 7, image 1 of 1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: step 8, image 1 of 3 HP 15-af013cl Motherboard Replacement: step 8, image 2 of 3 HP 15-af013cl Motherboard Replacement: step 8, image 3 of 3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: step 9, image 1 of 1
    • Carefully lift out the motherboard from the laptop.
Stephen Perreira
787 Reputation
6 Guides authored
Cal Poly, Team S8-G6, Banghart Fall 2017 Member of Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 20
All Time: 1,979
