Introduction
Project title: How to Replace a Keyboard on an HP Pavilion Series Laptop
Included:
- Checkpoint photo set (PDF, steps 1–8): 4 completed, hands-on photos (my HP Pavilion and my hand in frame) and labeled placeholders for the final four shots I’ll add after approval.
📄 iFixit_Checkpoint_Photo_Set_Nancy_Forvilus-Corvil.pdf - (Optional supporting docs for your records)
• 📄 Fast Fix Project Proposal
• 📄 Full iFixit Project – HP Pavilion Keyboard
What the attached photos show (Steps 1–4 completed):
- Powering down and unplugging the HP Pavilion
- Flipping the laptop to access the bottom panel/battery area
- Identifying bottom-panel screws and battery latch
- Setting up the work area and parts tray
I plan to add the remaining shots (panel off, ribbon-cable unlock/lock, and final key test) immediately after checkpoint approval. Please let me know if these meet the EDU requirements or if you’d like any adjustments before I proceed.
Thank you for your time!
Remove all external devices from the computer.
Remove the charging cord from the computer.
Locate the Fan as shown.
Pull out the black cable, with four wires attached from its port.
Locate the four ribbon clips.
Lift the grey part of the ribbon clips.
Pull the ribbon cable out and repeat this step for all four ribbon cables.
Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
7 other people completed this guide.
3 Guide Comments
Did you have to use soldering iron to melt the plastic rivets when putting back the keyboard?
Cheers.
I have done these before and yes, using a soldering iron to melt the plastic rivets is a good method.
Helpful. Too good!
