HP 15-R011DX Motherboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
58
All Time:
1,090
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The motherboard is the main hub for every component in a laptop. For this reason, one should always know how to access and disconnect any component from a motherboard. Removing a motherboard is also a necessary prerequisite to accessing components such as the RAM and CPU.
Tools
    1. HP 15-R011DX Motherboard Replacement, Battery: step 1, image 1 of 2 HP 15-R011DX Motherboard Replacement, Battery: step 1, image 2 of 2
      • Slide the lock mechanism on the left side of the laptop to the right.
      Ask FixBot
    2. HP 15-R011DX Motherboard Replacement: step 2, image 1 of 1
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      Ask FixBot
    1. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 1 of 2 HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 2 of 2
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      Ask FixBot
    2. HP 15-R011DX Motherboard Replacement: step 4, image 1 of 2 HP 15-R011DX Motherboard Replacement: step 4, image 2 of 2
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      Ask FixBot
    3. HP 15-R011DX Motherboard Replacement: step 5, image 1 of 2 HP 15-R011DX Motherboard Replacement: step 5, image 2 of 2
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      Ask FixBot
    4. HP 15-R011DX Motherboard Replacement: step 6, image 1 of 3 HP 15-R011DX Motherboard Replacement: step 6, image 2 of 3 HP 15-R011DX Motherboard Replacement: step 6, image 3 of 3
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      Ask FixBot
    5. HP 15-R011DX Motherboard Replacement: step 7, image 1 of 2 HP 15-R011DX Motherboard Replacement: step 7, image 2 of 2
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      Ask FixBot
    1. HP 15-R011DX Motherboard Replacement, Hard Drive: step 8, image 1 of 1
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
      Ask FixBot
    2. HP 15-R011DX Motherboard Replacement: step 9, image 1 of 2 HP 15-R011DX Motherboard Replacement: step 9, image 2 of 2
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
      Ask FixBot
    3. HP 15-R011DX Motherboard Replacement: step 10, image 1 of 1
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
      Ask FixBot
    1. HP 15-R011DX Motherboard Replacement, Motherboard: step 11, image 1 of 2 HP 15-R011DX Motherboard Replacement, Motherboard: step 11, image 2 of 2
      • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
      Ask FixBot
    2. HP 15-R011DX Motherboard Replacement: step 12, image 1 of 1
      • Remove the tape from the display connector attached to the motherboard.
      • Disconnect the display connector from the motherboard.
      Ask FixBot
    3. HP 15-R011DX Motherboard Replacement: step 13, image 1 of 1
      • Remove one 4 mm Phillips #1 screw from the wireless chip.
      • Remove the wireless chip from the motherboard.
      Ask FixBot
    4. HP 15-R011DX Motherboard Replacement: step 14, image 1 of 1
      • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
      • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
      Ask FixBot
    5. HP 15-R011DX Motherboard Replacement: step 15, image 1 of 1
      • Slowly lift the motherboard out of the computer.
      • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
      • Disconnect the power connector from the motherboard as shown in the image.
      Ask FixBot
3 other people completed this guide.
Ethan Guillotte
517 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 58
All Time: 1,090
