HP 15-AF131DX Speaker Replacement
  1. HP 15-AF131DX Speaker Replacement, Speakers: step 1, image 1 of 2 HP 15-AF131DX Speaker Replacement, Speakers: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Speaker Replacement: step 2, image 1 of 2 HP 15-AF131DX Speaker Replacement: step 2, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the speakers.
  3. HP 15-AF131DX Speaker Replacement: step 3, image 1 of 3 HP 15-AF131DX Speaker Replacement: step 3, image 2 of 3 HP 15-AF131DX Speaker Replacement: step 3, image 3 of 3
    • Pull up on each individual speaker, removing the rubber holds from their plastic pins.
    • Unplug the wire that connects the speakers.
    • Carefully remove the speakers from their plastic holds.
Anthony Martinez
526 Reputation
3 Guides authored
Cal Poly, Team S6-G2, Banghart Fall 2017 Member of Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 601
