Remove the 10 same-sized Philips screws.
Use a tiny flathead screwdriver to pry the rubber feet off, and remove each of the screws under where the rubber feet were. These screws, as you may notice, are longer than the others.
Slide out the optical drive, if there is one.
Flip the laptop on its side, optical drive hole up, and use a nice n' long spudger to push the keyboard out through the hole above where the optical drive was. Light always helps to pinpoint the hole.
Once the keyboard starts popping up, get under it with your fingers and pull.
Set the laptop down to normal position, unlock the keyboard connector, and remove the keyboard cable from the connector.
Remove the four screws securing the palmrest to the base.
Remove the touchpad and power button cables from their connectors.
Flip the laptop bottom-up, and remove the remaining two screws holding the palmrest.
