HP Omen 2015 laptop Thermal coupler Replacement
    • Remove all cables, power to laptop. On the bottom of LT, remove & discard rubber feet, destroyed on removal. Remove 12 phillips screws, 00, under the rubbers & gently pry bottom from laptop with a slight forward pressure to clear the tabs holding the bottom at the rear-cover should come off easily after this with access to fans & cooling.
    • Remove all phillips screws holding thermal unit w/fans, clean 2 processors of old thermal paste with alcohol & instal new thermal unit, paste already applied to new unit from HP. Recable unit, replace screws & close bottom of the LT. Add 4 self-stick rubber feet to the bottom to raise the pc @ 1/4" off a flat surface-this allows better air flow.
    • Reattach power & cables, power up-R&R complete, no break-in required
steven stein
97 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 126
