HMDX Jam Plus Speaker Replacement
  1. HMDX Jam Plus Speaker Replacement, Battery: step 1, image 1 of 3 HMDX Jam Plus Speaker Replacement, Battery: step 1, image 2 of 3 HMDX Jam Plus Speaker Replacement, Battery: step 1, image 3 of 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Speaker Replacement: step 2, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Speaker Replacement: step 3, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 3, image 2 of 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Speaker Replacement: step 4, image 1 of 3 HMDX Jam Plus Speaker Replacement: step 4, image 2 of 3 HMDX Jam Plus Speaker Replacement: step 4, image 3 of 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Speaker Replacement: step 5, image 1 of 3 HMDX Jam Plus Speaker Replacement: step 5, image 2 of 3 HMDX Jam Plus Speaker Replacement: step 5, image 3 of 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Speaker Replacement: step 6, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 6, image 2 of 2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus Speaker Replacement, Speaker: step 7, image 1 of 2 HMDX Jam Plus Speaker Replacement, Speaker: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
  8. HMDX Jam Plus Speaker Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to pry the glue away from the wire. Be careful not to damage the wire.
  9. HMDX Jam Plus Speaker Replacement: step 9, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to separate the center plastic piece from the rest of the device.
    • Gently lift the center plastic piece and feed the speaker wire through the hole.
  10. HMDX Jam Plus Speaker Replacement: step 10, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 10, image 2 of 2
    • Use the plastic opening tool to separate the speaker grate from the rest of the device.
  11. HMDX Jam Plus Speaker Replacement: step 11, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 11, image 2 of 2
    • Carefully remove the speaker through the top of the device.
    • Apply new adhesive to the edge of the replacement speaker and the edge of the speaker grate to ensure they do not wiggle loose.
Maxwell Erickson
587 Reputation
4 Guides authored
Montana Tech, Team 10-3, Shirk Fall 2015 Member of Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,382
