HMDX Jam Battery Replacement
  1. HMDX Jam Battery Replacement, Opening speaker: step 1, image 1 of 1
    • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
  2. HMDX Jam Battery Replacement, remove rubber cover: step 2, image 1 of 1
    • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
  3. HMDX Jam Battery Replacement, Remove screws: step 3, image 1 of 1
    • Once you have exposed the screws, use a #1 Philips Head star screw driver to remove the four 9 mm screws.
    • It would be wise to use a magnetic mat for the screws for safekeeping.
  4. HMDX Jam Battery Replacement, Exposing Battery: step 4, image 1 of 1
    • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
  5. HMDX Jam Battery Replacement, Removing Battery: step 5, image 1 of 1
    • Very gently remove the battery from the motherboard.
  6. HMDX Jam Battery Replacement, Remove battery attachments: step 6, image 1 of 2 HMDX Jam Battery Replacement, Remove battery attachments: step 6, image 2 of 2
    • Use a solder gun to remove the battery attachments from the motherboard.
Prince Tendai Dzonga
656 Reputation
1 Guide authored
USF Tampa, Team 1-1, Blackwell Winter 2015 Member of USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Members
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 151
All Time: 95,178
