HMDX Chill Disassembly
  1. HMDX Chill Disassembly, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 3 of 3
    • Insert a metal spudger under the rubber base and pry the rubber base off.
  2. HMDX Chill Disassembly, Unscrew the Four Bottom Screws: step 2, image 1 of 3 HMDX Chill Disassembly, Unscrew the Four Bottom Screws: step 2, image 2 of 3 HMDX Chill Disassembly, Unscrew the Four Bottom Screws: step 2, image 3 of 3
    • Remove the four 0.9 inch Phillips screws from the base of the device.
  3. HMDX Chill Disassembly, Remove the Base of the Speaker: step 3, image 1 of 2 HMDX Chill Disassembly, Remove the Base of the Speaker: step 3, image 2 of 2
    • Grip the base of the HMDX Chill and pull upwards.
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,433
