HMDX Chill Battery Replacement
  1. HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 3 of 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Battery Replacement: step 3, image 1 of 2 HMDX Chill Battery Replacement: step 3, image 2 of 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Battery Replacement, Locate the Battery: step 4, image 1 of 2 HMDX Chill Battery Replacement, Locate the Battery: step 4, image 2 of 2
    • Once the base has been removed from the rest of the speaker locate the battery.
    • It may or may not be in a wrapper.
  5. HMDX Chill Battery Replacement, Unsolder the Battery: step 5, image 1 of 2 HMDX Chill Battery Replacement, Unsolder the Battery: step 5, image 2 of 2
    • Locate the wires that attaches from the battery to the motherboard.
    • Using a soldering iron desolder the wires from the motherboard.
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 10
All Time: 667
