Shop the Holiday Gift Guide
HDD Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
3
All Time:
176
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
HDD Removal
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. HDD Removal, Unfasten the HDD hatch: step 1, image 1 of 2 HDD Removal, Unfasten the HDD hatch: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
      Ask FixBot
    2. HDD Removal, Remove the HDD hatch: step 2, image 1 of 3 HDD Removal, Remove the HDD hatch: step 2, image 2 of 3 HDD Removal, Remove the HDD hatch: step 2, image 3 of 3
      • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
      • Remove the HDD hatch.
      Ask FixBot
    3. HDD Removal, Unfasten the HDD assembly: step 3, image 1 of 2 HDD Removal, Unfasten the HDD assembly: step 3, image 2 of 2
      • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
      • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
      Ask FixBot
    4. HDD Removal: step 4, image 1 of 3 HDD Removal: step 4, image 2 of 3 HDD Removal: step 4, image 3 of 3
      • Firmly grip the HDD assembly and HDD cable connector head.
      • Pull the HDD cable connector out of its socket.
      • Remove the HDD assembly.
      Ask FixBot
Spencer Day
210,488 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 176
