This teardown is not a repair guide. To repair your Twingo III, use our service manual.
    1. H4D: Lubrication, Oil pan: step 1, image 1 of 1
      • Oil pan retaining screw: 10 N.m
      • Drain plug: 50 N.m
      • The pan has a volume of approximately 3.7 L without the filter and 4.3 L with the filter. The volume difference between the MIN and MAX marks on the oil dipstick is approximately 1.0 L.
      Ask FixBot
    2. H4D: Lubrication, Oil filtration: step 2, image 1 of 1
      • No specified torque for the oil filter: tighten by hand with lubrication of the gasket.
      Ask FixBot
    3. H4D: Lubrication, Oil pump, oil squirters: step 3, image 1 of 2 H4D: Lubrication, Oil pump, oil squirters: step 3, image 2 of 2
      • The oil pump is driven by a secondary chain connected to the crankshaft sprocket. It features variable displacement and an electronic on-off valve, which acts as a pressure limiter from 4,500 RPM.
      • 25 N.m
      • 10 N.m
      • Unknown torque, torque tightening is necessary.
      • The oil squirters do not appear anywhere in the repair manual (RTA), which is why no torque value is given here. Torque tightening of these screws is necessary.
      Ask FixBot
    4. H4D: Lubrication, Oil vapor breather: step 4, image 1 of 1
      • 10 N·m
      Ask FixBot
AntonioTwingo
8,113 Reputation
45 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 67
All Time: 1,357
