H4D: MAP Sensor Cleaning
    1. H4D: MAP Sensor Cleaning, Accessing the engine hood: step 1, image 1 of 1
      • Open the trunk.
      • Remove the trunk carpets.
      Ask FixBot
    2. H4D: MAP Sensor Cleaning, Acessing the engine compartment: step 2, image 1 of 1
      • Unscrew the 6 screws by hand or with a T50 socket.
      • Lift and set aside the engine hood.
      Ask FixBot
    1. H4D: MAP Sensor Cleaning, Pressure Sensor Removal: step 3, image 1 of 2 H4D: MAP Sensor Cleaning, Pressure Sensor Removal: step 3, image 2 of 2
      • Disconnect the pressure sensor connector.
      • Gently remove the pressure sensor by pulling it upwards. The sensor must be rotated in a specific way to be removed.
      • The sensor is difficult to extract, even with slim fingers. Those with thicker fingers may not be able to perform this operation without using a tool.
      • Breaking the MAP sensor during removal would require removing the intake manifold, which is a complex procedure.
      Ask FixBot
      • Gently spray contact cleaner in short bursts into the pressure sensor's orifice.
      • Shake the sensor, allow the liquid to drain out, and repeat the process several times.
      • Let the sensor dry for a few minutes.
      • Certain products, or simply repeated cleaning combined with wear, will eventually lead to the inevitable replacement of the MAP sensor.
      Ask FixBot
      • Bosch Motorsports recommends:
      • Lubricating the seals with a drop of engine oil (e.g., 5W40).
      • Avoid using silicone-based lubricants or grease.
      • Insert the pressure sensor into its position until it is fully seated.
      • Reconnect the pressure sensor connector.
      Ask FixBot
Congratulations! You've just cleaned your intake pressure sensor!
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
João Pedro Domingues is helping us fix the world! Want to contribute?
Start translating ›
AntonioTwingo
8,102 Reputation
45 Guides authored
3 Guide Comments
Attention , cette intervention a l’air facile à faire donc je me suis dit pourquoi pas …
En retirant le capteur, la tétine tenue par deux joints c’est cassé à l’intérieur du collecteur d’admission d’air 🤦‍♂️pourtant j’y suis allé doucement !
J’ai aussitôt commandé un nouveau capteur m.a.p
J’ai dû démonter le collecteur d’admission d’air pour retirer ce gros bout de plastique qui se baladait dedans car il risquait de finir dans une soupape et de faire de gros dégâts…
Pour démonter le collecteur d’admission d’air j’ai dû démonter :
Tuyau de boîte à air,boîtier papillon,rampe d’injection,pot d’échappement, catalyseur, tuyaux de liquide de refroidissement, câble électrique, mettre la voiture sur chandelles de chaque côté pour pouvoir dévisser les deux boulons de Silent bloc moteur et faire descendre le moteur de 20 cm environ à l’aide d’un cric car c’est la seul façon de retirer ce collecteur d’air
La voiture n’a pas roulé 1 semaines le temps que le nouveau capteur m.a.p arrive.
Donc faite attention !
Philippe - Reply Share
J'avais l'impression que le capteur MAP retournait une valeur qui ne variait pas et que mes corrections d'injection étaient folles (STFT systématiquement à -10/20% au ralenti et parfois l'opposé en charge, et que la lambda large bande lisait toujours trop pauvre même si la lambda de contrôle disait que tout était ok, et le LTFT entre +12 et +18%).
J'ai cassé le capteur en essayant de le retirer (je pense qu'il était déjà déchiré mais pas séparé en deux) mais le mamelon qui est inséré dans le collecteur d'admission est resté coincé. En utilisant une vis à bois 5x50, du dégrippant une heure avant pour décoller les joints, ainsi qu'une clef à molette assez longue et plate en guise de fourche pour faire levier sur la vis, tout en la mettant légèrement de travers, j'ai pu sortir le mamelon entier et installer un nouveau capteur.
Superflan - Reply Share
Bonjour,
Je suppose vous avez tenté de regarder la valeur du capteur MAP (147) avec un adaptateur OBD standard, et une application basique, or, il est impossible de la consulter ainsi. Seule la pression atmosphérique extérieure (probablement la valeur fixe que vous évoquez) est accessible en OBD standard.
Pour consulter la valeur du capteur MAP (147) en mbar, vous devez obligatoirement utiliser une application qui utilise les PID propriétaires de Renault, ou une valise (piratée ou non).
Vous décrivez des fluctuations importantes du lambda. Quel carburant ? Combien de kilomètres ont les sondes ?
Pour moi, le remplacement des deux sondes (242 et 1587) est à prévoir. Ça peut aussi être des pointes d'injecteurs (193, 194, 195) encrassés : c'est un défaut de conception du recyclage des vapeurs d'huile. (voir tutoriel et wiki).
Le remplacement du capteur MAP a t-il résolu votre défaut ?
Attention : d'expérience, les capteurs MAP (147) "cheap" ne sont pas précis. Ça se sent à la pédale.
AntonioTwingo - Reply Share
Past 24 Hours: 9
Past 7 Days: 42
Past 30 Days: 183
All Time: 5,474
