Guide 2: Nespresso coffee machines don't fill with water after long idle time
  1. Guide 2: Nespresso coffee machines don't fill with water after long idle time, Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 1, image 1 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time, Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 1, image 2 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time, Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 1, image 3 of 3
    • Various Nespresso coffee machines models don't pump water after months of storage and disuse. It's a very common problem in this type coffee maker, the tubing inside dries out and the machine can't pump water. After trying a couple of times, let's look at home-brewed method to get water flowing from the tank.
    • First—Remove the water tank.
  2. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 2, image 1 of 1
    • We need the following two things for this procedure:
    • A syringe, the bigger the better. In this case I use a 20ml one.
  3. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 3, image 1 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 3, image 2 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 3, image 3 of 3
    • Second: A piece of foam or sponge. Ideally as rigid as possible. A piece of wide rubber that exceeds the diameter of the syringe can also work.
  4. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 4, image 1 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 4, image 2 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 4, image 3 of 3
    • We will make a hole in the sponge up to half of its depth so that the mouth of the syringe can rest in it.
    • We will make a small opening so that when we insert the syringe, the tip will protrude slightly beyond the sponge.
  5. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 5, image 1 of 1
    • Using the syringe, we will fill the hole where the water reservoir rests.
  6. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 6, image 1 of 2 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 6, image 2 of 2
    • Support the sponge or foam with the syringe, completely covering the hole
    • In the photos we see that the syringe is inclined, I chose to make the hole in the sponge in this inclined fashion so it will work with the greatest number of coffee makers, since depending on the type of tank, some protrude at the rear and the syringe could be obstructed by the machine.
    • This way is more versatile, maximizing compatibility for more models.
  7. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 7, image 1 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 7, image 2 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 7, image 3 of 3
    • First. Having positioned the syringe, press down so that the water does not escape through the side.
    • Second. Press the button for a large cup, for example.
    • Third. Press the plunger down completely while the water pump is running.
    • Fourth. As soon as we empty the syringe, press the button again to stop the pump.
    • Fifth. We remove the syringe.
  8. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 8, image 1 of 1
    • Using the syringe, we fill the hole where the water reservoir rests.
  9. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 9, image 1 of 1
    • Put the filled water reservoir in its place.
  10. Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 10, image 1 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 10, image 2 of 3 Guide 2: Nespresso coffee machines don't fill with water after long idle time: step 10, image 3 of 3
    • With the water reservoir correctly placed, lift the capsule lever completely.
    • Press the large coffee button.
    • When water starts to flow from the reservoir, close the lever to ensure that water begins to flow.
    • Our problem is hereby solved.
    • If this method doesn't solve the problem, we can try repeating it, and if the machine still doesn't suck in water, we'll only have to disassemble it to manually prime the water inlet hose to the pump.
    • Explanatory video of the 2nd Option.
Well done. Try to cycle the coffee machine every once in a while to prevent this from happening again
2 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
88,972 Reputation
303 Guides authored
5 Guide Comments
Das geht einfacher mit einem Luftballon.
Der Wassertank wird ca. halb gefüllt. Dann Maschine einschalten und die Pumpe starten. Während das Gerät pumpt, den Luftballon im Wassertank aufblasen und so einen Überdruck erzeugen.
Vorteil: Kein Gefummelt mit einem Gummiadapter für die Aufnahme vom Wassertank und die Wassermenge im halb gefüllten Tank reicht locker für das Leitungssystem, so dass nichts nachgefüllt werden muss.
Mc Guiver - Reply
TRADUCCION Esto es más fácil con un globo. Llena el depósito de agua hasta la mitad. A continuación, enciende la máquina y pon en marcha la bomba. Mientras la máquina bombea, infla el globo en el depósito de agua para crear una sobrepresión. Ventaja: no hay que juguetear con un adaptador de goma para sujetar el depósito de agua y la cantidad de agua del depósito medio lleno es fácilmente suficiente para el sistema de tuberías, de modo que no hay que rellenar nada.
Carlos López (España - Spain) -
Muchas gracias por tu aporte, entiendo que metes el globo dentro del deposito de agua? ¿es asi?
Musste im Urlaub eine Plastiktüte statt eines Luftballons verwenden - hat aber trotzdem funktioniert. Vielen Dank!
BuzzDee -
TRADUCIDO:
Tuve que usar una bolsa de plástico en vez de un globo en vacaciones, pero funcionó. Muchas gracias.
Muchas gracias a ti BuzzDee
Carlos López (España - Spain) - Reply
Past 24 Hours: 76
Past 7 Days: 466
Past 30 Days: 2,280
All Time: 35,486
