Introduction
A side panel is located on each side of the device. The right side panel, containing the button(s), controls the track being selected as well as the volume of the device. There are no prerequisites required for this guide.
- A pry bar is necessary to remove the panel.
Use the plastic opening tool to lodge its tip into the corner of the device, applying upward pressure on the edge of the panel until the corner is released.
The side panel should now be easily detached using your fingers.
The side panel's buttons can be dislodged by turning the panel over and shaking it if necessary.
