Greatcall Jitterbug Smart2 Battery Replacement
      • Pull the back cover away from the body of the device. It will clip in multiple locations around the edge of the device.
      Ask FixBot
      • Unscrew the screws from the back of the device. None are hidden.
      Ask FixBot
      • Remove the antenna clips located on the bottom and top of the device on the back.
      Ask FixBot
      • Pry the Mid-Frame away from the screen. It is clipped on around the edged.
      • Be careful near the buttons as the flex cable runs upwards.
      Ask FixBot
      • Disconnect the battery press connector.
      Ask FixBot
      • Disconnect the Main FPC press connectors.
      Ask FixBot
      • Heat the device lightly.
      • Apply alcohol to the edges, around the battery.
      • Remove the battery from the device.
      Ask FixBot
Cici
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 56
All Time: 146
