Introduction
Use this guide to replace the vibrator on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The vibrator replacement includes the vibrator and battery replacement.
Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
Using opening plastic tool, pry the two grey cases from both sides of the device.
While pry off the grey cases, hold the device with your other hand to remove the cases.
Pry the edges of the device to separate the front case away from the rare case.
While prying the edges, hold the device with one hand to pull out each case a part.
Pick up the motherboard carefully.
Using plastic opening tool, pry and remove the vibrator part.
