Graco Secure Coverage LED Parent Unit Replacement
  1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: step 1, image 1 of 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: step 1, image 2 of 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: step 1, image 3 of 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage LED Parent Unit Replacement: step 2, image 1 of 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: step 3, image 1 of 2 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: step 3, image 2 of 2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage LED Parent Unit Replacement: step 4, image 1 of 2 Graco Secure Coverage LED Parent Unit Replacement: step 4, image 2 of 2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases
  5. Graco Secure Coverage LED Parent Unit Replacement: step 5, image 1 of 1
    • Pry the edges of the device to separate the front and rare cases.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage LED Parent Unit Replacement: step 6, image 1 of 2 Graco Secure Coverage LED Parent Unit Replacement: step 6, image 2 of 2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
  7. Graco Secure Coverage LED Parent Unit Replacement: step 7, image 1 of 2 Graco Secure Coverage LED Parent Unit Replacement: step 7, image 2 of 2
    • Flip over the motherboard.
    • Solder off LED from motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
    • Replace the LED's
Bryson Wolff
237 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 95
