Google Pixelbook Motherboard Replacement
  1. Google Pixelbook Motherboard Replacement, Battery (Back Panel): step 1, image 1 of 3 Google Pixelbook Motherboard Replacement, Battery (Back Panel): step 1, image 2 of 3 Google Pixelbook Motherboard Replacement, Battery (Back Panel): step 1, image 3 of 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Motherboard Replacement: step 2, image 1 of 2 Google Pixelbook Motherboard Replacement: step 2, image 2 of 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Motherboard Replacement: step 3, image 1 of 3 Google Pixelbook Motherboard Replacement: step 3, image 2 of 3 Google Pixelbook Motherboard Replacement: step 3, image 3 of 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Motherboard Replacement: step 4, image 1 of 3 Google Pixelbook Motherboard Replacement: step 4, image 2 of 3 Google Pixelbook Motherboard Replacement: step 4, image 3 of 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Motherboard Replacement: step 5, image 1 of 2 Google Pixelbook Motherboard Replacement: step 5, image 2 of 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Motherboard Replacement: step 6, image 1 of 2 Google Pixelbook Motherboard Replacement: step 6, image 2 of 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Motherboard Replacement: step 7, image 1 of 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Motherboard Replacement, Left Charging Port: step 8, image 1 of 2 Google Pixelbook Motherboard Replacement, Left Charging Port: step 8, image 2 of 2
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
  9. Google Pixelbook Motherboard Replacement: step 9, image 1 of 2 Google Pixelbook Motherboard Replacement: step 9, image 2 of 2
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Motherboard Replacement: step 10, image 1 of 1
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
  11. Google Pixelbook Motherboard Replacement: step 11, image 1 of 1
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
  12. Google Pixelbook Motherboard Replacement: step 12, image 1 of 2 Google Pixelbook Motherboard Replacement: step 12, image 2 of 2
    Tool used on this step:
    Buy
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
  13. Google Pixelbook Motherboard Replacement: step 13, image 1 of 2 Google Pixelbook Motherboard Replacement: step 13, image 2 of 2
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
  14. Google Pixelbook Motherboard Replacement: step 14, image 1 of 1
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
  15. Google Pixelbook Motherboard Replacement: step 15, image 1 of 2 Google Pixelbook Motherboard Replacement: step 15, image 2 of 2
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
  16. Google Pixelbook Motherboard Replacement, Right Charging Port: step 16, image 1 of 2 Google Pixelbook Motherboard Replacement, Right Charging Port: step 16, image 2 of 2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  17. Google Pixelbook Motherboard Replacement: step 17, image 1 of 1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  18. Google Pixelbook Motherboard Replacement: step 18, image 1 of 1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  19. Google Pixelbook Motherboard Replacement: step 19, image 1 of 1
    • Remove the small, red component by lifting it up with the spudger.
  20. Google Pixelbook Motherboard Replacement: step 20, image 1 of 1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  21. Google Pixelbook Motherboard Replacement: step 21, image 1 of 2 Google Pixelbook Motherboard Replacement: step 21, image 2 of 2
    Buy
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
  22. Google Pixelbook Motherboard Replacement, Motherboard: step 22, image 1 of 2 Google Pixelbook Motherboard Replacement, Motherboard: step 22, image 2 of 2
    • Disconnect the flat, black cord from the motherboard by using a spudger to push it upwards out of the slot, or by using your hand to carefully pull upward.
  23. Google Pixelbook Motherboard Replacement: step 23, image 1 of 3 Google Pixelbook Motherboard Replacement: step 23, image 2 of 3 Google Pixelbook Motherboard Replacement: step 23, image 3 of 3
    • Fold back the plastic covering on the motherboard using the nylon spudger.
  24. Google Pixelbook Motherboard Replacement: step 24, image 1 of 3 Google Pixelbook Motherboard Replacement: step 24, image 2 of 3 Google Pixelbook Motherboard Replacement: step 24, image 3 of 3
    • Disconnect the two black cables from the motherboard by pulling the connectors upward using the needle-nose tweezers.
  25. Google Pixelbook Motherboard Replacement: step 25, image 1 of 3 Google Pixelbook Motherboard Replacement: step 25, image 2 of 3 Google Pixelbook Motherboard Replacement: step 25, image 3 of 3
    • Disconnect the flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
  26. Google Pixelbook Motherboard Replacement: step 26, image 1 of 3 Google Pixelbook Motherboard Replacement: step 26, image 2 of 3 Google Pixelbook Motherboard Replacement: step 26, image 3 of 3
    • Disconnect the large flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
  27. Google Pixelbook Motherboard Replacement: step 27, image 1 of 3 Google Pixelbook Motherboard Replacement: step 27, image 2 of 3 Google Pixelbook Motherboard Replacement: step 27, image 3 of 3
    • Raise the retaining latch of the motherboard connector by using the needle-nose tweezers.
    • Disconnect the large flat cable from the motherboard by gently pulling on the latch using the needle-nose tweezers.
  28. Google Pixelbook Motherboard Replacement: step 28, image 1 of 3 Google Pixelbook Motherboard Replacement: step 28, image 2 of 3 Google Pixelbook Motherboard Replacement: step 28, image 3 of 3
    • Disconnect the flat cable from the motherboard by using the needle-nose tweezers to gently pull the connector out of the slot.
  29. Google Pixelbook Motherboard Replacement: step 29, image 1 of 2 Google Pixelbook Motherboard Replacement: step 29, image 2 of 2
    • Remove the gold 3.0mm screws and the black, flat 2.0mm screws from the motherboard by using a T3 Torx screwdriver to turn the screws counterclockwise.
  30. Google Pixelbook Motherboard Replacement: step 30, image 1 of 3 Google Pixelbook Motherboard Replacement: step 30, image 2 of 3 Google Pixelbook Motherboard Replacement: step 30, image 3 of 3
    • Remove the motherboard by gently lifting it out of the laptop using the needle-nose tweezers.
Logan Lawson
410 Reputation
1 Guide authored
Cal Poly, Team S18-G1, Livingston Winter 2018 Member of Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Members
7 Guides authored
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 87
All Time: 13,412
