Up to 20% off select tools
Google Pixelbook Go Trackpad Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
11
Past 30 Days:
46
All Time:
46
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. Google Pixelbook Go Trackpad Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Trackpad Replacement, Back Panel: step 1, image 2 of 2
      • Flip the device so that the back is facing up.
      • Peel the rubber stoppers off the top and bottom of the device.
      Ask FixBot
    2. Google Pixelbook Go Trackpad Replacement: step 2, image 1 of 2 Google Pixelbook Go Trackpad Replacement: step 2, image 2 of 2
      • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    3. Google Pixelbook Go Trackpad Replacement: step 3, image 1 of 3 Google Pixelbook Go Trackpad Replacement: step 3, image 2 of 3 Google Pixelbook Go Trackpad Replacement: step 3, image 3 of 3
      • Use an iFixit opening tool to pry up the back panel cover.
      • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
      • Remove the single 2 mm screw using a Torx T3 screwdriver.
      • Disconnect the orange cable from the base of the device.
      Ask FixBot
    4. Google Pixelbook Go Trackpad Replacement: step 4, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    5. Google Pixelbook Go Trackpad Replacement: step 5, image 1 of 1
      • address the touchpad assembly. Remove the screws securing the touchpad mounting bracket at the lower center of the frame. Gently lift the touchpad assembly along with its attached ribbon cable out of the chassis housing.
      Ask FixBot
Shreyas vuyyuru
288 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 46
All Time: 46
