Google Pixelbook Go Left Charging Port Replacement
  1. Google Pixelbook Go Left Charging Port Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Left Charging Port Replacement, Back Panel: step 1, image 2 of 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
    Ask FixBot
  2. Google Pixelbook Go Left Charging Port Replacement: step 2, image 1 of 2 Google Pixelbook Go Left Charging Port Replacement: step 2, image 2 of 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
    Ask FixBot
  3. Google Pixelbook Go Left Charging Port Replacement: step 3, image 1 of 3 Google Pixelbook Go Left Charging Port Replacement: step 3, image 2 of 3 Google Pixelbook Go Left Charging Port Replacement: step 3, image 3 of 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
    Ask FixBot
  4. Google Pixelbook Go Left Charging Port Replacement: step 4, image 1 of 1
    • Insert wisdom here.
    Ask FixBot
  5. Google Pixelbook Go Left Charging Port Replacement, Left Charging Port: step 5, image 1 of 1
    • Find the left side of the device by locating the white stickers
    • Remove the three pink screws using a T3 Torx screwdriver.
    Ask FixBot
  6. Google Pixelbook Go Left Charging Port Replacement: step 6, image 1 of 2 Google Pixelbook Go Left Charging Port Replacement: step 6, image 2 of 2
    • Carefully grab the silver tab and slide the left charging port out of the laptop.
    Ask FixBot
Harleen Chahal
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 427
