Google Pixel XL Charging Assembly Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Google Pixel XL Charging Assembly Replacement, Charging Assembly: step 1, image 1 of 2 Google Pixel XL Charging Assembly Replacement, Charging Assembly: step 1, image 2 of 2
      • Using a T5 Torx screwdriver, unscrew the two 3 mm screws from the daughterboard.
      Ask FixBot
    2. Google Pixel XL Charging Assembly Replacement: step 2, image 1 of 2 Google Pixel XL Charging Assembly Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of precision tweezers, carefully peel the orange tape from the frame.
      Ask FixBot
    3. Google Pixel XL Charging Assembly Replacement: step 3, image 1 of 2 Google Pixel XL Charging Assembly Replacement: step 3, image 2 of 2
      • Using a blue plastic opening tool, detach the connector by gently pulling to the right.
      • Applying too much force may result in damaging the black connector and/or the cable.
      Ask FixBot
    4. Google Pixel XL Charging Assembly Replacement: step 4, image 1 of 1
      • Gently lift the daughterboard out of the device.
      • To replace the charging assembly, you will need to replace the entire daughterboard.
      Ask FixBot
Julia List
6,299 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 148
