Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Before starting your repair:
Remove your watch from the charger.
Press and hold the crown button, then tap Power off to shut down your watch.
Remove each watch band by depressing the release button and sliding the band out of its groove.
Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
Make sure the O‑rings are on the screws before installing them.
Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
Gently lift the back glass and flip it over the side of the watch opposite the crown.
