Google Pixel Watch 2 Opening Procedure
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel Watch 2 Opening Procedure, Prepare your watch for disassembly: step 1, image 1 of 2 Google Pixel Watch 2 Opening Procedure, Prepare your watch for disassembly: step 1, image 2 of 2
      • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
      • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
      Ask FixBot
    2. Google Pixel Watch 2 Opening Procedure, Remove both watch bands: step 2, image 1 of 2 Google Pixel Watch 2 Opening Procedure, Remove both watch bands: step 2, image 2 of 2
      • Remove both watch bands by pressing the release button and sliding the band out of its groove.
      Ask FixBot
    3. Google Pixel Watch 2 Opening Procedure, Put your watch in the vise: step 3, image 1 of 1
      • Inserting a tool between the screen and frame is very difficult. Using a vise to secure the frame makes it significantly easier.
      • Secure your watch with a small vise so the jaws go into the watch band grooves on the frame.
      • If your vice has sharp or metal jaws, consider wrapping the frame in a thin cloth to prevent scratching or damaging the frame.
      Ask FixBot
    4. Google Pixel Watch 2 Opening Procedure, Safety precautions: step 4, image 1 of 1
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Wear gloves to protect yourself.
      Ask FixBot
    5. Google Pixel Watch 2 Opening Procedure, Heat the screen adhesive: step 5, image 1 of 1
      • Very strong adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Use a hair dryer or heat gun to heat the right edge of screen around the watch crown until it's slightly too hot to touch.
      • Be careful not to heat the screen more than this, as it may damage the screen and/or battery.
      Ask FixBot
    6. Google Pixel Watch 2 Opening Procedure, Insert an iFlex: step 6, image 1 of 3 Google Pixel Watch 2 Opening Procedure, Insert an iFlex: step 6, image 2 of 3 Google Pixel Watch 2 Opening Procedure, Insert an iFlex: step 6, image 3 of 3
      • Insert the tip of an iFlex between the screen and frame just below the watch crown (opposite the side button).
      • This is very difficult and will take multiple attempts. If the screen cools down, apply more heat and try again.
      • Rotate the iFlex so its longer edge is between the screen and frame.
      Ask FixBot
    7. Google Pixel Watch 2 Opening Procedure, Separate the screen adhesive: step 7, image 1 of 3 Google Pixel Watch 2 Opening Procedure, Separate the screen adhesive: step 7, image 2 of 3 Google Pixel Watch 2 Opening Procedure, Separate the screen adhesive: step 7, image 3 of 3
      • Hold the iFlex at a slight upward angle and slide it clockwise around the perimeter of the watch to separate the adhesive. Stop when you reach the side button.
      • Don't slide farther than this or you'll damage the screen cable.
      Ask FixBot
    8. Google Pixel Watch 2 Opening Procedure, Remove your watch from the vise: step 8, image 1 of 1
      • Remove your watch from the vise.
      Ask FixBot
    9. Google Pixel Watch 2 Opening Procedure, Disassembly information: step 9, image 1 of 2 Google Pixel Watch 2 Opening Procedure, Disassembly information: step 9, image 2 of 2
      • Throughout the rest of your repair:
      • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
      • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
      Ask FixBot
    10. Google Pixel Watch 2 Opening Procedure, Swing open the screen: step 10, image 1 of 3 Google Pixel Watch 2 Opening Procedure, Swing open the screen: step 10, image 2 of 3 Google Pixel Watch 2 Opening Procedure, Swing open the screen: step 10, image 3 of 3
      E6000 Adhesive Glue
      $2.99
      Buy
      • Be careful not to strain the screen cable during the rest of your repair.
      • Swing open the screen and put it in an upright position next to the watch crown.
      • If the screen feels stuck, go back around the perimeter and carefully separate any remaining adhesive with the iFlex. Be very careful not to damage the screen cable near the crown.
      • During reassembly:
      • This is a good point to plug in and test your watch before sealing it up. Be sure to power it down completely before you continue working.
      • Use a spudger and tweezers to remove all the old screen adhesive from the frame and screen. Then, clean up any adhesive residue with high‑concentration (>90%) isopropyl alcohol and a cotton swab.
      • You'll need to seal your watch with strong adhesive glue. Apply the glue to the perimeter of the frame and firmly press the screen into place.
      • Most strong adhesive glues have a long curing time—read the instructions for proper use.
      Ask FixBot
Spencer Day
205,821 Reputation
1,267 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 225
