Google Pixel Tablet USB-C Port Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel Tablet USB-C Port Removal, Disconnect the USB-C port: step 1, image 1 of 2 Google Pixel Tablet USB-C Port Removal, Disconnect the USB-C port: step 1, image 2 of 2
      • Use the flat end of your spudger to pry up and disconnect the USB-C port press connector.
      Ask FixBot
    2. Google Pixel Tablet USB-C Port Removal, Remove the USB-C cable tape: step 2, image 1 of 3 Google Pixel Tablet USB-C Port Removal, Remove the USB-C cable tape: step 2, image 2 of 3 Google Pixel Tablet USB-C Port Removal, Remove the USB-C cable tape: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Be careful not to damage the battery with your tool during this step.
      • Use blunt nose tweezers or your fingers to peel up and remove the three strips of tape securing the USB-C port cable to the battery.
      • During reassembly, reuse these strips of tape if they're in good condition. If not, cut and apply a few thin strips of electrical tape to re-secure the cable to the battery.
      Ask FixBot
    3. Google Pixel Tablet USB-C Port Removal, Unfasten the USB-C port: step 3, image 1 of 1
      • Use your Torx Plus 3IP driver to remove the four 3.2 mm screws securing the USB-C port.
      Ask FixBot
    4. Google Pixel Tablet USB-C Port Removal, Remove the USB-C port: step 4, image 1 of 3 Google Pixel Tablet USB-C Port Removal, Remove the USB-C port: step 4, image 2 of 3 Google Pixel Tablet USB-C Port Removal, Remove the USB-C port: step 4, image 3 of 3
      • Pull the USB-C port out of its recess in the frame and remove it.
      Ask FixBot
Clay Eickemeyer
107,837 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 144
