Google Pixel C Keyboard Replacement
  1. Google Pixel C Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
    • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
  2. Google Pixel C Keyboard Replacement: step 2, image 1 of 2 Google Pixel C Keyboard Replacement: step 2, image 2 of 2
    • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
  3. Google Pixel C Keyboard Replacement: step 3, image 1 of 2 Google Pixel C Keyboard Replacement: step 3, image 2 of 2
    • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
    • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
    • The screws are reverse threaded, so to remove them rotate clockwise.
  4. Google Pixel C Keyboard Replacement: step 4, image 1 of 1
    • Orient the keyboard so that the side with the keys is facedown on the table.
    • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
    • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
  5. Google Pixel C Keyboard Replacement: step 5, image 1 of 3 Google Pixel C Keyboard Replacement: step 5, image 2 of 3 Google Pixel C Keyboard Replacement: step 5, image 3 of 3
    • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
    • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
    • Be mindful of the amount of force applied to avoid snapping the keyboard.
    • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
Makenzie Kamei
137 Reputation
1 Guide authored
Cal Poly, Team S21-G4, Livingston Spring 2017 Member of Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Members
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,929
