Introduction
This guide shows how to install the logic board in your Google Pixel 9a smartphone.
Check the condition of the logic board thermal pads—they'll either be on the bottom of the board or stuck to the corresponding spot on the frame.
If the pads are ripped, torn, or otherwise damaged, follow the next five steps to replace them. If they aren't, skip ahead five steps.
Use the flat end of a spudger to scrape up and remove the damaged thermal pads.
Remove the textured liner from the smaller thermal pad.
Carefully place the pad onto the board.
Use the flat end of a spudger or your finger to press down lightly on the entire surface of the thermal pad, securing it in place without deforming it.
Slide the logic board up against the frame so the screen cable is near its connector.
Align the screen cable press connector over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place.
Use tweezers to hook the bottom edge of the screen cable cover into place, then lay the cover down flat.
Flip the logic board up so it's gently resting in its recess in the frame.
Remove the suction cup and lay your phone screen-side down.
Push the logic board toward the bottom of the frame and press the charging port down until it snaps into its cutout.
Press down on the center of the logic board's bottom edge until the clip near the battery engages.
Use a 3IP Torx Plus screwdriver to install the two 2.8 mm‑long screws securing the logic board.
