PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
141
All Time:
4,334
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to remove the lower smart plate of your PlayStation 2 to get access to the internal parts or how to replace it.
Tools
    1. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement, Lower Smart Plate: step 1, image 1 of 1
      • Turn off your PlayStation 2 and remove the disc and Memory Card.
      • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
      Ask FixBot
    2. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 2, image 1 of 1
      • Locate the six covers.
      • Two are located underneath the feet.
      • One cover is located underneath the Void sticker.
      Ask FixBot
    3. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 3, image 1 of 1
      • Remove the Void sticker with a Spudger and some cleaning alcohol
      • Removing the Void sticker will void the warranty of your device!
      • Some versions of that console maybe don’t have the sticker or it’s relocated.
      Ask FixBot
    4. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 4, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 4, image 2 of 2
      • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
      Ask FixBot
    5. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 5, image 1 of 1
      • Remove the six Phillips #1 screws with a screwdriver.
      • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
      Ask FixBot
    6. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 6, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: step 6, image 2 of 2
      • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
      • Separate the two halves.
      Ask FixBot
8 other people completed this guide.
Special thanks to these translators:
de en
100%
MrJulian is helping us fix the world! Want to contribute?
Start translating ›
MrJulian
3,776 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 141
All Time: 4,334
