This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Laça Tudo Usage Training
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
43
All Time:
259
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
    1. Laça Tudo Usage Training, Getting to know the Laça Tudo: step 1, image 1 of 1
      • A Laça Tudo is a launch by Lacito in Brazil.
      • It is a machine that offers safety, high production, and practicality, in addition to being a compact machine.
      • The LAÇA TUDO machine provides a solution for many industries to save on packaging costs and reduce labor intensity; with OPP plastic tape, it can seal vegetables, boxes, cards, all types of printing materials, and some daily stationery items.
      • The machine can seal objects of different sizes and shapes without the need for adjustments to the machine.
      • So come with me to learn more about the machine.
      Ask FixBot
    2. Laça Tudo Usage Training, POWER: step 2, image 1 of 1
      • The first step is to connect the power cable to the machine and to a 220-volt outlet.
      • Lacito Tip: When choosing a place to put the machine, choose a safe, spacious, and firm location that prevents risks to the integrity of the machine and its users—just don't get hurt (=.
      Ask FixBot
    3. Laça Tudo Usage Training, BUTTON FUNCTIONS: step 3, image 1 of 1
      • Now let's look at the functions of the remote control buttons:
      • Main switch, designed to energize and de-energize the machine for maintenance procedures.
      • Power button, designed to turn the machine on or off.
      • Lacito Tip: The machine meets all safety requirements against electric shock, so there is no need to be afraid.
      Ask FixBot
    4. Laça Tudo Usage Training, Turning on the Machine: step 4, image 1 of 3 Laça Tudo Usage Training, Turning on the Machine: step 4, image 2 of 3 Laça Tudo Usage Training, Turning on the Machine: step 4, image 3 of 3
      • Now that we know the button functions, we can turn on the machine.
      • To turn on the machine, activate the master switch, leaving the selector positioned at the I indicator (Photo 1).
      • Then press the (I) button to turn on the machine (Green) (Photo 2).
      • After 2 seconds, the control panel screen will light up (Photo 3).
      Ask FixBot
    5. Laça Tudo Usage Training, Let's get to know the control panel now, "Let's go.": step 5, image 1 of 3 Laça Tudo Usage Training, Let's get to know the control panel now, "Let's go.": step 5, image 2 of 3 Laça Tudo Usage Training, Let's get to know the control panel now, "Let's go.": step 5, image 3 of 3
      • Now, we can start discovering the functions of the control panel. I don't know about you, but I couldn't wait.
      • The + button is used to increase the machine's sealing temperature.
      • The - button is used to decrease the machine's sealing temperature (Photo 1).
      • The machine's operating range is from 100°C to 180°C. 130°C is recommended.
      • The MT/AT button is used to switch between automatic and manual operating modes or vice versa (Photo 2).
      • The FUN button is used to enter the parameter configuration mode; there are 7 parameters in total.
      • Lacito Tip: The control panel is responsible for communication between the operator and the machine.
      Ask FixBot
    6. Laça Tudo Usage Training, PARAMETER SETTINGS: step 6, image 1 of 3 Laça Tudo Usage Training, PARAMETER SETTINGS: step 6, image 2 of 3 Laça Tudo Usage Training, PARAMETER SETTINGS: step 6, image 3 of 3
      • Now that we know the functions of the numeric keypad, let's start exploring the functions of the control panel, my favorite part.
      • Press the "FUN" key once; the temperature display value flashes, indicating that the machine has entered the parameter setting state.
      • Temperature value = 01: adjust the Tape tightness (the factory value is 6), press , the operating range is 1-30; the adjustment must be made according to the object to be sealed and the necessary tightness. To adjust, use the + and - keys.
      • Press the FUN key again to switch to the next setting item;
      • Temperature value = 02: adjust the length of the tape tail after sealing (the factory value is 6), press the + or - keys to enter the required value, the value range (0-30). The higher the value, the longer the tail length, otherwise, it is shorter.
      • Press the "FUN" key again to switch to the next setting item; use the driver to enter the package perimeter and the value.
      • Temperature value = 03: start the sensor sensitivity adjustment (the factory value is 19), press the + or - keys to enter the required value, value range (3-60); the higher the value, the slower the response, otherwise it is more sensitive. Press the "function" key again to switch to the next setting item.
      Ask FixBot
    7. Laça Tudo Usage Training: step 7, image 1 of 3 Laça Tudo Usage Training: step 7, image 2 of 3 Laça Tudo Usage Training: step 7, image 3 of 3
      • Temperature value = 4: initial delay time (the factory setting is 1), press the key to enter the desired value, range (1-9), each value represents 0.5s.
      • Press the FUN key again to switch to the next configuration item;
      • Temperature value = 5: set the tensioning time, this is the time the machine stretches the strap for sealing, the selection range is (1-10), and press "+" and "-" to enter the required value.
      • Temperature value = 6: adjust the strap cooling time, selection range is (6-30). Press the "+" and "-" keys to adjust the cooling time. The higher the value, the longer the cooling time. Adjust according to the principle that the greater the pulling force on the secured object, the longer the cooling time required.
      Ask FixBot
    8. Laça Tudo Usage Training: step 8, image 1 of 1
      • Temperature value = 7: sets the speed at which the OPP Tape is applied to the machine; the adjustment range is (1-11). The higher the value, the faster the OPP Tape application speed. A speed that is too fast will cause the OPP Tape to become loose in the conveyor channel, resulting in irregular OPP Tape feeding.
      Ask FixBot
    9. Laça Tudo Usage Training: step 9, image 1 of 3 Laça Tudo Usage Training: step 9, image 2 of 3 Laça Tudo Usage Training: step 9, image 3 of 3
      • Now let's load the OPP Tape rolls into the machine.
      • First, open the front cover of the machine and pull out the roll tray at the bottom. (Photos 1 and 2)
      • After that, place the roll in the tray according to photo 3.
      • Remember, the roll must be unwound in the same position as in Photo 3.
      Ask FixBot
    10. Laça Tudo Usage Training: step 10, image 1 of 3 Laça Tudo Usage Training: step 10, image 2 of 3 Laça Tudo Usage Training: step 10, image 3 of 3
      • After that, take the end of the tape and pass it through the initial roller as shown in Photo 1.
      • Then pass the tape through the center guide and the center roller, as shown in Photo 2.
      • Then pass the tape through the center roller. (Photo 3)
      • Continues:
      Ask FixBot
    11. Laça Tudo Usage Training: step 11, image 1 of 2 Laça Tudo Usage Training: step 11, image 2 of 2
      • Now insert the Tray into the machine, as shown in Photos 1 and 2.
      Ask FixBot
    12. Laça Tudo Usage Training: step 12, image 1 of 3 Laça Tudo Usage Training: step 12, image 2 of 3 Laça Tudo Usage Training: step 12, image 3 of 3
      • Finally, insert the tape into the feeder and hold the tape in the feeder. (Photo 1 and 2)
      • With the tape positioned in the feeder, press the ENTER button on the inside of the machine. (Photo 3)
      • The machine should then pull the tape, after which the machine will be ready for use. (Photo 3)
      Ask FixBot
    13. Laça Tudo Usage Training: step 13, image 1 of 3 Laça Tudo Usage Training: step 13, image 2 of 3 Laça Tudo Usage Training: step 13, image 3 of 3
      • The machine should now pull the strap; it will then be ready for use. (Photo 1)
      • The operator can then select the operating mode: manual or automatic.
      • To change the mode, simply press the MT/AT key on the control panel. The machine will indicate on the display which mode it is in, automatic or manual. (Photos 2 and 3)
      Ask FixBot
    14. Laça Tudo Usage Training: step 14, image 1 of 2 Laça Tudo Usage Training: step 14, image 2 of 2
      • If the machine is in automatic mode, simply bring the object you wish to seal and move it close to the proximity sensor located on the machine base. Photos 1 and 2.
      • When the operator moves the object close to the sensor, the machine will immediately seal the merchandise. (Photo 2)
      • The strap tension depends on the parameterization entered on the configuration screen. To adjust it, press the FUN key on the control panel.
      • The temperature display value flashes, indicating that the machine has entered the parameter configuration state.
      • To adjust the tension setting, the flashing value must be set to 1; the operator can then adjust the tension between 1 and 70. The lower the value, the tighter the strap.
      • CAUTION: Do not insert your fingers inside the strap arch or the strap sealing zone, as there is a risk of incurring some level of burns, depending on the machine's operating temperature.
      • In automatic mode, the operator must be very careful not to trigger the machine involuntarily, because if an object is detected by the sensor, the machine will begin operation.
      Ask FixBot
    15. Laça Tudo Usage Training: step 15, image 1 of 2 Laça Tudo Usage Training: step 15, image 2 of 2
      • To use the machine in manual mode, you must connect the pedal to the back of the machine; connect the cable to the connector and tighten the locking nut.
      • After that, check which mode the machine is in, Manual or Automatic. If it is in Automatic, press the AT/MT key to switch to manual mode.
      • With the machine in manual mode, simply place the box inside the strapping arch and press the pedal with your foot to start the machine's operation.
      • CAUTION: Do not insert your fingers into the strapping arch or the strap sealing area, as there is a risk of suffering some degree of burns, depending on the machine's operating temperature.
      Ask FixBot
    16. Laça Tudo Usage Training: step 16, image 1 of 3 Laça Tudo Usage Training: step 16, image 2 of 3 Laça Tudo Usage Training: step 16, image 3 of 3
      • With the machine in Manual mode, simply place the box inside the strap arch and press the pedal with your foot; the machine will immediately seal the package. (Photos 1, 2, and 3)
      • CAUTION: Do not insert your fingers into the strap arch or the strap sealing area, as there is a risk of burns, depending on the machine's operating temperature.
      Ask FixBot
    17. Laça Tudo Usage Training: step 17, image 1 of 1
      • We've reached the end. Leave a comment telling us what you thought—it's important for us to always be improving.
      • See you later.
      Ask FixBot
Finish Line
Special thanks to these translators:
pt en
100%
redratchet21 is helping us fix the world! Want to contribute?
Start translating ›
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 43
All Time: 259
