Google Pixel 6 Camera Glass Panel Replacement
    1. Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: step 1, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: step 1, image 2 of 2
      • Use the wet wipe included in your kit to clean the rear camera glass panel.
      • Dry off the rear camera glass panel with the dry wipe.
      Ask FixBot
    2. Google Pixel 6 Camera Glass Panel Replacement: step 2, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 2, image 2 of 2
      • Carefully cut around the edges of the phone's rear glass panel using an X-Acto knife.
      • Caution: Hazardous situation which involves a sharp utensil and glass fragments.
      Ask FixBot
    3. Google Pixel 6 Camera Glass Panel Replacement: step 3, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 3, image 2 of 2
      • Using the tweezers, begin chipping and tweezing away at the cracked region.
      • Caution: Shards and shrapnel can splinter off of the panel.
      • Keep some masking tape near to be able to pick up shrapnel without injuring yourself.
      Ask FixBot
    4. Google Pixel 6 Camera Glass Panel Replacement: step 4, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 4, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 4, image 3 of 3
      • Use the metal spudger to remove the larger pieces of the glass to expose the layer underneath.
      • Caution: Hastily removing sharp fragments pieces could result in injury.
      Ask FixBot
    5. Google Pixel 6 Camera Glass Panel Replacement: step 5, image 1 of 2 Google Pixel 6 Camera Glass Panel Replacement: step 5, image 2 of 2
      • Use the opening tool to remove excess glue leftover from the old glass panel.
      • Perform this step only when all glass has been removed from the camera area.
      Ask FixBot
    6. Google Pixel 6 Camera Glass Panel Replacement: step 6, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 6, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 6, image 3 of 3
      • Take a piece of masking tape about 3 inches wide.
      • Gently press the masking tape (sticky side down) onto the rear camera lens and lift, removing the glass debris.
      • Repeat until most of the glass debris is removed.
      Ask FixBot
    7. Google Pixel 6 Camera Glass Panel Replacement: step 7, image 1 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 7, image 2 of 3 Google Pixel 6 Camera Glass Panel Replacement: step 7, image 3 of 3
      • Align the glass panel replacement with the exposed camera area.
      • Press the glass panel firmly into the camera area.
      • Do not press too hard to avoid cracking glass from excess pressure.
      • Let the glass panel adhesive dry for approximately two hours before using the phone.
      Ask FixBot
Finish Line
Aliyah Sims
154 Reputation
1 Guide authored
UC Davis, Team 1-6, Andersen Winter 2025 Member of UC Davis, Team 1-6, Andersen Winter 2025
UCD-ANDERSEN-W25S1G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 208
All Time: 2,907
