Vixen 21 Oil Cooler Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
66
All Time:
2,509
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
    1. Vixen 21 Oil Cooler Replacement, Oil Cooler: step 1, image 1 of 1
      • After removing the side panel, it's clear that my oil cooler has been leaking for a while. Fortunately, AFAB sells a complete replacement kit including a new oil cooler and new hoses!
      Ask FixBot
    2. Vixen 21 Oil Cooler Replacement: step 2, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 2, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 2, image 3 of 3
      • The tail light covers come off easy enough with 10 screws and a single connector.
      • The white housing beneath comes off with a bolt on the left and a screw on the right.
      Ask FixBot
    3. Vixen 21 Oil Cooler Replacement: step 3, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 3, image 2 of 2
      • On my Vixen there was a hex head bolt on the top right, and a on-its-way-to-being-stripped Phillips head bolt on the top left.
      Ask FixBot
    4. Vixen 21 Oil Cooler Replacement: step 4, image 1 of 1
      • There were two Phillips screws in the bottom of the panel, but these weren't actually attached to anything.
      • My new side-routed exhaust definitely made it harder to get this panel out.
      Ask FixBot
    5. Vixen 21 Oil Cooler Replacement: step 5, image 1 of 1
      • There's one electrical plug and 4 obvious hex bolts to remove the condenser fan.
      Ask FixBot
    6. Vixen 21 Oil Cooler Replacement: step 6, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 6, image 2 of 2
      • Once the condenser fan is removed we can get a good look at the oil cooler. The fittings are certainly leaking, but the cooler itself might actually be fine.
      • The Vixen bleeds black and I bleed red, whoops!
      Ask FixBot
    7. Vixen 21 Oil Cooler Replacement: step 7, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 7, image 2 of 2
      • Here's all the shiny new replacement parts. You can buy the oil cooler kit from AFAB.
      • I made a mess of the threads putting one of the blue aluminum fittings in to the top of the new oil cooler. Thanks to a 1/2" NPT tap and die from Harbor Freight and a friend's help I was able to salvage it and I don't think it leaks, but time will tell...
      Ask FixBot
    8. Vixen 21 Oil Cooler Replacement: step 8, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 8, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 8, image 3 of 3
      • On a closer inspection, all my existing fittings are leaking, which at this point I suppose is a good sign.
      Ask FixBot
    9. Vixen 21 Oil Cooler Replacement: step 9, image 1 of 1
      • Getting the oil cooler off the condenser was easy, there's just two bolts. But it's still attached to the engine...
      Ask FixBot
    10. Vixen 21 Oil Cooler Replacement: step 10, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 10, image 2 of 2
      • It was easy enough to loosen the hose clamps and pop the hoses off.
      • This made a mess, because not surprisingly, there's oil in the lines.
      Ask FixBot
    11. Vixen 21 Oil Cooler Replacement: step 11, image 1 of 1
      • The old oil cooler is out!
      Ask FixBot
    12. Vixen 21 Oil Cooler Replacement: step 12, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 12, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 12, image 3 of 3
      • There was a lot of oil/dust sludge beneath the oil cooler, requiring a rather dirty cleanup.
      Ask FixBot
    13. Vixen 21 Oil Cooler Replacement: step 13, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 13, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 13, image 3 of 3
      • Removing the remaining couplers was quite challenging.
      • I was able to borrow some large metric wrenches (24 mm and 27 mm) from a friend to help with this step.
      Ask FixBot
    14. Vixen 21 Oil Cooler Replacement: step 14, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 14, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 14, image 3 of 3
      • After the first fitting was off, I was able to get a 24 mm socket over the second one to remove the fitting.
      Ask FixBot
    15. Vixen 21 Oil Cooler Replacement: step 15, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 15, image 2 of 2
      • I routed the new lines the same as the old ones.
      • The plastic lining the hole the hoses go through is definitely decaying, but seems like it'll still protect the hoses ok.
      Ask FixBot
    16. Vixen 21 Oil Cooler Replacement: step 16, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 16, image 2 of 2
      • The lines are just barely long enough, but it reaches!
      Ask FixBot
    17. Vixen 21 Oil Cooler Replacement: step 17, image 1 of 3 Vixen 21 Oil Cooler Replacement: step 17, image 2 of 3 Vixen 21 Oil Cooler Replacement: step 17, image 3 of 3
      • Mounting to the condenser is straightforward.
      Ask FixBot
    18. Vixen 21 Oil Cooler Replacement: step 18, image 1 of 2 Vixen 21 Oil Cooler Replacement: step 18, image 2 of 2
      • Everything's in place!
      • I spent some more time cleaning the dirty panel below. Thus far I have no leaks from the new oil cooler!
      Ask FixBot
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 66
All Time: 2,509
