Zoll Impact Uni-Vent 731 Power Knob Kit Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
65
All Time:
464
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
This information can be found on page 29 of the Zoll Impact Uni-Vent 731 Ventilator Guide on the iFixit page for the ventilator. This is a simple repair that can be done on this model of Zoll ventilator and should be done whenever there is damage to the power knob.
Parts
Tools
    1. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement, Power Knob Kit: step 1, image 1 of 1
      • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake
      • Pg. 29
      Ask FixBot
    2. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 2, image 1 of 1
      • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator
      • Pg. 29
      Ask FixBot
    3. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 3, image 1 of 1
      • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”
      • Pg. 29
      Ask FixBot
    4. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 4, image 1 of 1
      • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module
      • Pg. 29
      Ask FixBot
    5. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 5, image 1 of 1
      • Remove the bezel by loosening and removing the (7) 4-40 X ¼ screws that hold the bezel to the front case
      • Pg. 29
      Ask FixBot
    6. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 6, image 1 of 1
      • On the membrane panel assembly, loosen the 6-32 X ¼ set screw using a 1/16 Ball Hex Driver (located in the power knob) and lift the damaged knob from the membrane panel
      • Pg. 30
      Ask FixBot
    7. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 7, image 1 of 1
      • Place the replacement knob on the membrane panel switch -align with flat on switch –insert the included 6-32 X ¼ set screw and tighten
      • Pg. 30
      Ask FixBot
    8. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 8, image 1 of 1
      • Install the new bezel by tightening the included (7) 4-40 X ¼ screws
      • Pg. 30
      Ask FixBot
    9. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 9, image 1 of 1
      • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position
      • Pg. 30
      Ask FixBot
    10. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 10, image 1 of 1
      • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws
      • Pg. 30
      Ask FixBot
    11. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 11, image 1 of 1
      • Tighten the (4) 8-32 X 3 screws on the outer air intake
      • Pg. 30
      Ask FixBot
    12. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 12, image 1 of 1
      • Perform HiPot Testing then perform Calibration and Functional Test using the RCS
      • Pg. 30
      Ask FixBot
Emily
206 Reputation
1 Guide authored
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 464
