Sony Xperia Z1 Charging Port Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
87
All Time:
2,511
Comments: 12
12 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
Over time, charging ports can wear out or become damaged. This can lead to inconsistent connections between the contacts of your phone and charging cable, causing slow or non-existent charging. This guide will help you swap out the faulty port of your Sony Xperia Z1 with a replacement and bring your phone’s charging capabilities back to normal.
Before you begin replacing the port, make sure the issue isn’t caused by a damaged cable, faulty power adapter, or debris inside the charging port. It’s also a good idea to confirm that the phone isn't limited by software or battery-related issues.
Once you’re ready to start, power off your phone and disconnect any cables.
Tools
    1. Sony Xperia Z1 Charging Port Replacement, Battery: step 1, image 1 of 1
      • Before you begin, use caution while handling a heat gun.
      • With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
      Ask FixBot
    2. Sony Xperia Z1 Charging Port Replacement: step 2, image 1 of 2 Sony Xperia Z1 Charging Port Replacement: step 2, image 2 of 2
      • Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
      • If you are experiencing difficulty, use an opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
      Ask FixBot
    3. Sony Xperia Z1 Charging Port Replacement: step 3, image 1 of 2 Sony Xperia Z1 Charging Port Replacement: step 3, image 2 of 2
      • Use the Torx T5 screwdriver to remove the two 3.81mm screws from the corners of the battery.
      Ask FixBot
    4. Sony Xperia Z1 Charging Port Replacement: step 4, image 1 of 2 Sony Xperia Z1 Charging Port Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the plastic opening tool to gently pry off the two flex connectors from the motherboard. Getting access to one of the connectors requires prying off the other first, so be sure to remove the top connector first.
      • Tip: you may need to use the tweezers to gently hold the top connector out of the way while prying off the bottom connector.
      Ask FixBot
    5. Sony Xperia Z1 Charging Port Replacement: step 5, image 1 of 1
      Halberd Spudger
      $2.99
      Buy
      • Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
      Ask FixBot
    6. Sony Xperia Z1 Charging Port Replacement: step 6, image 1 of 1
      • Use the tweezers to grab the top right corner of battery and carefully lift it up and away from the phone.
      Ask FixBot
    7. Sony Xperia Z1 Charging Port Replacement: step 7, image 1 of 1
      • Once the battery is at a safe enough height, grip the corner of the battery and slowly pull it out of the phone.
      • The old battery can be recycled at any local office supply store that supports recycling used batteries.
      Ask FixBot
    1. Sony Xperia Z1 Charging Port Replacement, Charging Port: step 8, image 1 of 3 Sony Xperia Z1 Charging Port Replacement, Charging Port: step 8, image 2 of 3 Sony Xperia Z1 Charging Port Replacement, Charging Port: step 8, image 3 of 3
      Buy
      • Use a T5 Torx screwdriver to remove the two screws on the long metal bracket along the left side of the phone.
      • Remove the metal cover with a pair of tweezers.
      Ask FixBot
    2. Sony Xperia Z1 Charging Port Replacement: step 9, image 1 of 1
      • Use a pair of tweezers to remove the plastic cover above the speakers.
      Ask FixBot
    3. Sony Xperia Z1 Charging Port Replacement: step 10, image 1 of 1
      • Use a plastic opening tool to remove the coaxial cable from the bottom of the motherboard by prying it upward.
      Ask FixBot
    4. Sony Xperia Z1 Charging Port Replacement: step 11, image 1 of 1
      • Using the plastic opening tool, remove the press fit connector attached to the motherboard.
      Ask FixBot
    5. Sony Xperia Z1 Charging Port Replacement: step 12, image 1 of 1
      • Using the plastic opening tool, remove the press fit connector attached to the motherboard in the upper righthand corner.
      Ask FixBot
    6. Sony Xperia Z1 Charging Port Replacement: step 13, image 1 of 2 Sony Xperia Z1 Charging Port Replacement: step 13, image 2 of 2
      • Using the plastic opening tool, remove the press fit camera connector from the motherboard.
      • Lift the camera out from the motherboard.
      Ask FixBot
    7. Sony Xperia Z1 Charging Port Replacement: step 14, image 1 of 3 Sony Xperia Z1 Charging Port Replacement: step 14, image 2 of 3 Sony Xperia Z1 Charging Port Replacement: step 14, image 3 of 3
      • Using a plastic spudger, lift the motherboard upwards in order to separate it from the phone.
      • The images depict a metal spudger being used, which poses a potential to damage the motherboard. We recommend using an ESD-safe tool instead.
      • As the motherboard is lifted up, grab it with a pair of tweezers and lift it out of the phone.
      Ask FixBot
    8. Sony Xperia Z1 Charging Port Replacement: step 15, image 1 of 2 Sony Xperia Z1 Charging Port Replacement: step 15, image 2 of 2
      • Grab your Soldering Iron and heat it up. Once it is at around 200° F, apply pressure to the soldering pads on the left and right side of the connector. In order to replace the charging port, grab your connector and solder it back onto the same soldering pads.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 87
All Time: 2,511
