Google Pixel 3a XL Midframe Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 3a XL Midframe Replacement, Midframe: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the following 4.3mm screws:
      • 14 silver T3 Torx screws
      • 2 black T3 Torx screws
      • Due to manufacturing tolerances, a T4 Torx driver may fit better into these T3 screws.
      Ask FixBot
    2. Google Pixel 3a XL Midframe Replacement: step 2, image 1 of 3 Google Pixel 3a XL Midframe Replacement: step 2, image 2 of 3 Google Pixel 3a XL Midframe Replacement: step 2, image 3 of 3
      • The midframe is still held in place by plastic clips.
      • Insert an opening pick into the seam along the bottom of the phone.
      • Slide the pick along the seam to release the clips holding the midframe to the rest of the phone.
      Ask FixBot
    3. Google Pixel 3a XL Midframe Replacement: step 3, image 1 of 3 Google Pixel 3a XL Midframe Replacement: step 3, image 2 of 3 Google Pixel 3a XL Midframe Replacement: step 3, image 3 of 3
      • Slide the opening pick along the left and right edges of the phone to release the midframe clips there.
      • Once the clips along the bottom of the phone are separated, the flat edge of the opening pick should be enough to separate the rest of the clips.
      • Lift up the bottom edge of the midframe but don’t completely remove it yet. The midframe is still connected to the phone by a fragile cable.
      Ask FixBot
    4. Google Pixel 3a XL Midframe Replacement: step 4, image 1 of 2 Google Pixel 3a XL Midframe Replacement: step 4, image 2 of 2
      • Use a spudger to pry up and detach the proximity sensor cable from the motherboard.
      Ask FixBot
    5. Google Pixel 3a XL Midframe Replacement: step 5, image 1 of 1
      • Remove the midframe from the phone.
      Ask FixBot
    6. Google Pixel 3a XL Midframe Replacement: step 6, image 1 of 2 Google Pixel 3a XL Midframe Replacement: step 6, image 2 of 2
      • During reassembly, align the top edge of the midframe with the top of the phone, then use a spudger to carefully press the proximity sensor cable connector onto its socket.
      • This takes a bit of patience and finesse. Once you have the connector aligned, you can also use a finger to gently press the connector onto the socket.
      Ask FixBot
Taylor Dixon
72,995 Reputation
94 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 274
