Google Pixel 2 XL Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Google Pixel 2 XL Opening Procedure, Opening Procedure: step 1, image 1 of 2 Google Pixel 2 XL Opening Procedure, Opening Procedure: step 1, image 2 of 2
    • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  2. Google Pixel 2 XL Opening Procedure: step 2, image 1 of 3 Google Pixel 2 XL Opening Procedure: step 2, image 2 of 3 Google Pixel 2 XL Opening Procedure: step 2, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  3. Google Pixel 2 XL Opening Procedure: step 3, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 3, image 2 of 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
    • Do not cut along the left edge; there are delicate display cables that can be damaged.
    • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
  4. Google Pixel 2 XL Opening Procedure: step 4, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 4, image 2 of 2
    • Slide the opening pick down the right side of the phone to separate the display adhesive.
  5. Google Pixel 2 XL Opening Procedure: step 5, image 1 of 3 Google Pixel 2 XL Opening Procedure: step 5, image 2 of 3 Google Pixel 2 XL Opening Procedure: step 5, image 3 of 3
    • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
    • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
  6. Google Pixel 2 XL Opening Procedure: step 6, image 1 of 3 Google Pixel 2 XL Opening Procedure: step 6, image 2 of 3 Google Pixel 2 XL Opening Procedure: step 6, image 3 of 3
    • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
  7. Google Pixel 2 XL Opening Procedure: step 7, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 7, image 2 of 2
    • Gently lift the display from the right side of the phone, opening it like a book.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
    • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
    • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
  8. Google Pixel 2 XL Opening Procedure: step 8, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 8, image 2 of 2
    • Use the corner of an opening tool to pry up the digitizer cable connector cover.
    • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
    • Remove the connector cover.
    • Make sure to keep this component so you can reinstall it during reassembly.
  9. Google Pixel 2 XL Opening Procedure: step 9, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 9, image 2 of 2
    • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  10. Google Pixel 2 XL Opening Procedure: step 10, image 1 of 1
    • Use tweezers to remove any tape from the display connector cover.
  11. Google Pixel 2 XL Opening Procedure: step 11, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 11, image 2 of 2
    • Insert the point of a spudger into the small hole on the edge of the display connector cover.
    • Use the spudger to pry the cover out of its recess.
  12. Google Pixel 2 XL Opening Procedure: step 12, image 1 of 2 Google Pixel 2 XL Opening Procedure: step 12, image 2 of 2
Adam O'Camb
197,590 Reputation
416 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 19
All Time: 172
