Google Pixel 10 Pro XL Battery Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 10 Pro XL Battery Installation, Clean the battery recess: step 1, image 1 of 3 Google Pixel 10 Pro XL Battery Installation, Clean the battery recess: step 1, image 2 of 3 Google Pixel 10 Pro XL Battery Installation, Clean the battery recess: step 1, image 3 of 3
      • Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
      • If the battery came out cleanly, you can skip this step.
      • Remove any bits of plastic from the old battery sleeve.
      • Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
      • Be careful not to get alcohol in the cutouts in the battery recess—the bottom of the screen is exposed and may get damaged.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    2. Google Pixel 10 Pro XL Battery Installation, Remove the battery liner: step 2, image 1 of 1
      • Remove the large, colored liner from the battery to expose the adhesive.
      Ask FixBot
    3. Google Pixel 10 Pro XL Battery Installation, Install the battery: step 3, image 1 of 3 Google Pixel 10 Pro XL Battery Installation, Install the battery: step 3, image 2 of 3 Google Pixel 10 Pro XL Battery Installation, Install the battery: step 3, image 3 of 3
      • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
      • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
      • Lay the battery into its recess and press down firmly to secure it.
      Ask FixBot
    4. Google Pixel 10 Pro XL Battery Installation, Disconnect the battery: step 4, image 1 of 2 Google Pixel 10 Pro XL Battery Installation, Disconnect the battery: step 4, image 2 of 2
      • Use a spudger to pry up and disconnect the battery.
      Ask FixBot
    5. Google Pixel 10 Pro XL Battery Installation: step 5, image 1 of 2 Google Pixel 10 Pro XL Battery Installation: step 5, image 2 of 2
      • Use your fingers to remove any remaining stickers or liners from the battery.
      Ask FixBot
Finish Line
Spencer Day
206,063 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 75
