Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Use the point of a spudger and tweezers to gently scrape up and remove all the old front camera adhesive.
Remove the large clear liner from the front camera adhesive and gently place it into the recess.
Use a spudger to press down firmly on the adhesive to secure it.
Slowly peel up and remove the remaining liner.
If your replacement front camera has a protective cap on the front, carefully remove it.
With the cable facing the bottom of the phone, lay the front camera into its recess and press it into place.
Slide the top corners of the front camera bracket under the lip in the frame and press the clip in to secure it.
Use your finger to press down and reconnect the front camera press connector.
Slide the tab on the left edge of the front camera connector cover into its slot and lay the cover down flat.
