Google Pixel 10 Pro Fold Outer Screen Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 10 Pro Fold Outer Screen Installation, Reconnect the outer screen: step 1, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation, Reconnect the outer screen: step 1, image 2 of 2
      • Support the screen with your hand or prop it up on something sturdy.
      • Reconnect the outer screen cable press connector.
      Ask FixBot
    2. Google Pixel 10 Pro Fold Outer Screen Installation, Place the display bracket: step 2, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation, Place the display bracket: step 2, image 2 of 2
      • Place the display bracket over its spot on the frame.
      Ask FixBot
    3. Google Pixel 10 Pro Fold Outer Screen Installation: step 3, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation: step 3, image 2 of 2
      • Use the point of a spudger to press down the display bracket and slide its clip under the bottom edge of the frame.
      Ask FixBot
    4. Google Pixel 10 Pro Fold Outer Screen Installation, Install the display bracket screws: step 4, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation, Install the display bracket screws: step 4, image 2 of 2
      • Use a Torx Plus 3IP driver to install the three screws securing the display cable bracket:
      • One 1.8 mm‑long screw
      • Two 2.5 mm‑long screws
      Ask FixBot
    5. Google Pixel 10 Pro Fold Outer Screen Installation, Expose the adhesive: step 5, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation, Expose the adhesive: step 5, image 2 of 2
      • Use tweezers to grip the pull tab of the secondary liner at the bottom left corner of the phone.
      Ask FixBot
    6. Google Pixel 10 Pro Fold Outer Screen Installation: step 6, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Installation: step 6, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Installation: step 6, image 3 of 3
      • Peel the liner from the left and top edge of the phone.
      Ask FixBot
    7. Google Pixel 10 Pro Fold Outer Screen Installation: step 7, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Installation: step 7, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Installation: step 7, image 3 of 3
      • While holding the screen over the frame, peel the liner from the right and bottom edge of the frame and expose the adhesive.
      Ask FixBot
    8. Google Pixel 10 Pro Fold Outer Screen Installation, Secure the outer screen: step 8, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Installation, Secure the outer screen: step 8, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Installation, Secure the outer screen: step 8, image 3 of 3
      • Align the outer screen over the frame and press it into place.
      Ask FixBot
    9. Google Pixel 10 Pro Fold Outer Screen Installation: step 9, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Installation: step 9, image 2 of 2
      • Press along the perimeter of the outer screen to adhere it to the frame.
      • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
      • Let the phone sit a few hours for the adhesive to cure.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 64
