Google Pixel 10 Pro Battery Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 10 Pro Battery Installation, Clean the battery recess: step 1, image 1 of 3 Google Pixel 10 Pro Battery Installation, Clean the battery recess: step 1, image 2 of 3 Google Pixel 10 Pro Battery Installation, Clean the battery recess: step 1, image 3 of 3
      • Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
      • If the battery came out cleanly, you can skip this step.
      • Remove any bits of plastic from the old battery sleeve.
      • Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
      • Be careful not to get alcohol in the cutouts in the battery recess—the bottom of the screen is exposed and may get damaged.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    2. Google Pixel 10 Pro Battery Installation, Remove the battery liner: step 2, image 1 of 1
      • Remove the large, colored liner from the battery to expose the adhesive.
      Ask FixBot
    3. Google Pixel 10 Pro Battery Installation, Install the battery: step 3, image 1 of 3 Google Pixel 10 Pro Battery Installation, Install the battery: step 3, image 2 of 3 Google Pixel 10 Pro Battery Installation, Install the battery: step 3, image 3 of 3
      • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
      • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
      • Lay the battery into its recess and press down firmly to secure it.
      Ask FixBot
    4. Google Pixel 10 Pro Battery Installation, Disconnect the battery: step 4, image 1 of 2 Google Pixel 10 Pro Battery Installation, Disconnect the battery: step 4, image 2 of 2
      • Use a spudger to pry up and disconnect the battery.
      Ask FixBot
    5. Google Pixel 10 Pro Battery Installation: step 5, image 1 of 2 Google Pixel 10 Pro Battery Installation: step 5, image 2 of 2
      • Use your fingers to remove any remaining stickers or liners from the battery.
      Ask FixBot
    6. Google Pixel 10 Pro Battery Installation, Put the interconnect cable into place: step 6, image 1 of 2 Google Pixel 10 Pro Battery Installation, Put the interconnect cable into place: step 6, image 2 of 2
      • Lay the interconnect cable back in place, making sure the connectors line up with their sockets.
      Ask FixBot
    7. Google Pixel 10 Pro Battery Installation, Reconnect the interconnect cable: step 7, image 1 of 3 Google Pixel 10 Pro Battery Installation, Reconnect the interconnect cable: step 7, image 2 of 3 Google Pixel 10 Pro Battery Installation, Reconnect the interconnect cable: step 7, image 3 of 3
      • Use your finger to press down and connect the both interconnect cable press connectors.
      Ask FixBot
    8. Google Pixel 10 Pro Battery Installation, Install the lower interconnect cable cover: step 8, image 1 of 2 Google Pixel 10 Pro Battery Installation, Install the lower interconnect cable cover: step 8, image 2 of 2
      • Put the lower interconnect cable cover back into place, sliding the tabs on the top corners under their hooks.
      Ask FixBot
    9. Google Pixel 10 Pro Battery Installation: step 9, image 1 of 2 Google Pixel 10 Pro Battery Installation: step 9, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the lower interconnect cable cover.
      Ask FixBot
    10. Google Pixel 10 Pro Battery Installation, Install the upper interconnect cable cover: step 10, image 1 of 2 Google Pixel 10 Pro Battery Installation, Install the upper interconnect cable cover: step 10, image 2 of 2
      • Put the upper interconnect cable cover back into place, sliding the tab on the left side into its slot.
      Ask FixBot
    11. Google Pixel 10 Pro Battery Installation: step 11, image 1 of 2 Google Pixel 10 Pro Battery Installation: step 11, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the 5.8 mm‑long screw securing the upper interconnect cable cover.
      Ask FixBot
Finish Line
Spencer Day
205,851 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 58
