Google Home Motherboard Replacement
    1. Google Home Motherboard Replacement, Interconnect Cable: step 1, image 1 of 3 Google Home Motherboard Replacement, Interconnect Cable: step 1, image 2 of 3 Google Home Motherboard Replacement, Interconnect Cable: step 1, image 3 of 3
      • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
      • Pull off the Google Home’s magnetically attached base and set it aside.
      • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
      • After all four screws are out, pop the lid off the device to open the capsule.
      Ask FixBot
    2. Google Home Motherboard Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully remove the interconnect cable using a pair of tweezers.
      Ask FixBot
    1. Google Home Motherboard Replacement, Mute Button Switch: step 3, image 1 of 2 Google Home Motherboard Replacement, Mute Button Switch: step 3, image 2 of 2
      • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
      Ask FixBot
    2. Google Home Motherboard Replacement: step 4, image 1 of 2 Google Home Motherboard Replacement: step 4, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
      • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
      Ask FixBot
    1. Google Home Motherboard Replacement, Motherboard: step 5, image 1 of 2 Google Home Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
      • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
      Ask FixBot
    2. Google Home Motherboard Replacement: step 6, image 1 of 2 Google Home Motherboard Replacement: step 6, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
      • Remove the motherboard.
      Ask FixBot
3 other people completed this guide.
Maya Wharton
208 Reputation
1 Guide authored
Cal Poly, Team S24-G11, Maness Spring 2018 Member of Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Members
60 Guides authored
2 Guide Comments
Where can one purchase a replacement motherboard?
Jim Pflasterer - Reply Share
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 88
All Time: 4,144
